I am interested in this too, let me know if you invest and try it!
If you happen to find out that the iX is supported by ABRP, could you post a reply here. I would appreciated it.Indeed, I tried on my iX with a OBDLink CX and Bimmercode & Bimmerlink apps, but the car is not recognized. I also tried with ABRP with the same OBDLink CX and ABRP simply doesn't have the OBD button enabled when you got to the car settings for the iX.
I reached out to ABRP and they have confirmed that the iX is currently not supported but they say they regularly add cars in the supported list (so hopefully soon?).
I'm mainly interested in ABRP support for OBD interface on the iX to get live data in ABRP.
So, if the CX is not compatible with the iX, does anyone have an OBD adapter that actually works with the iX (using any of the available smartphone (android) apps)?Indeed, I tried on my iX with a OBDLink CX and Bimmercode & Bimmerlink apps, but the car is not recognized. I also tried with ABRP with the same OBDLink CX and ABRP simply doesn't have the OBD button enabled when you got to the car settings for the iX.
interestingly the iX has started popping up on the coding websites as a supported option for the HUD basic mods (VIM, delete safety message, etc.) not sure if it is legitimate or not. I know HugoNZ has been able to achieve these mods however...So, if the CX is not compatible with the iX, does anyone have an OBD adapter that actually works with the iX (using any of the available smartphone (android) apps)?
I unfortunately bought the CX before reading these posts...and, yes, the CX doesn't recognize the iX. I'll return it for a refund, but would like to know if there is an adapter that works,
You should check out @Hugo_nz's work at BMW IX Coding ThreadI’ve only had my car a couple of weeks and had a few minutes to play with coding.
I’m using bimmerutility with esys. For the adapter I am using a wireless one from mgflasher which works perfectly.
I haven’t had a deep dive but so far most of the ECU are not available.
The 2 I’ve looked at that work are for the Idrive head unit and I’m guessing the ambient lighting.
There are a ton of codes in the Idrive unit which look configurable but I really haven’t had time to explore.
So far I’ve coded the disclaimer to be off, VIM, one touch indicator to 5 blinks (yes, that now works!)
ThanksYou should check out @Hugo_nz's work at BMW IX Coding Thread
