The fuse box is located under the black plastic cover located to the right of the gas pedal. Remove the plastic cover then you need to remove the small plastic cover of the fuse box.Anyone know where the fuse box is in the iX? Any pictures? Thanks!
How can I remove the black plastic cover located to the right of the gas pedal?The fuse box is located under the black plastic cover located to the right of the gas pedal. Remove the plastic cover then you need to remove the small plastic cover of the fuse box.
I see no snap locks. Can you please send a photo? Thank you.Use a clip plier to remove the snap locks
