Maybe someone with more understanding and experience would like to give their input here. I'd love to know the answer too.Vivek, thank you for the link. This link shows the ground clearance to be 8 inches, but it doesn’t mention the range with air suspension. I suspect it may be higher, but I don’t know. Anyone else with info?
Just measured it. 206mm parked and 227m when raised. I am not sure if the height changes when driving vs parked (lowers at high speed etc) but gives an idea of the additional clearance it gives.Vivek, thank you for the link. This link shows the ground clearance to be 8 inches, but it doesn’t mention the range with air suspension. I suspect it may be higher, but I don’t know. Anyone else with info?
Great! Thanks for sharing the info here. This will definitely help others who have a similar question, and this includes @TomInWA and me as well. Thanks again, @SF123!Just measured it. 206mm parked and 227m when raised. I am not sure if the height changes when driving vs parked (lowers at high speed etc) but gives an idea of the additional clearance it gives.
Thanks SF123. Very helpful. Did you test drive? What were your impressions of the vehicle?Just measured it. 206mm parked and 227m when raised. I am not sure if the height changes when driving vs parked (lowers at high speed etc) but gives an idea of the additional clearance it gives.
No problem. I’m in the UK and got my 50 on 1st March, not done huge amount of miles but on balance very happy with itThanks SF123. Very helpful. Did you test drive? What were your impressions of the vehicle?
