I activated drive assist as well, but it doesn't change the lane. I hit the turn signal, nothing happens.how do we get the car to auto lane change when drivers assist is activated? I have it activated in my settings. but then nothing happens when I hit the turn signal on the highway.
I see. will try it out. Thank you.You have to do the reduced turn signal where it would just flash theee times. I don’t know what that’s called. Not the full turn signal wheee it flashed until you turn it off. Then the car does the lane change and it keeps flashing until the new lane is acquired.
Like a half turn on the signal or let it blink 3 times ?You have to do the reduced turn signal where it would just flash theee times. I don’t know what that’s called. Not the full turn signal wheee it flashed until you turn it off. Then the car does the lane change and it keeps flashing until the new lane is acquired.
Full signaling (pushing the turn lever down until it starts to click) tells the car you want to do a manual turn or lane change - not Lane Change Assist. Just to the detente - not past - release, and the lever will return to its original position and lane change will activate (if conditions are met - green lane lines, indicating the car "sees" the lines, no incoming cars, steering and lane guidance activated). When active a green turn arrow will appear in the lane on the instrument cluster, indicating a lane change in the direction indicated. A better video:OK that is confusing
I was doing full signaling which then seemed to put me back into manual steering to allow me to change lane myself (or maybe it was because I started to move the wheel when the car wouldn't change lane?)
I do like that it will move in/out of steering control seamlessly when you do steering corrections unlike Tesla which exits out to manual and has to be re-activated.
The video demo above shows the driver using it 100km/h which is over 60mph, so presumably it should work above 40mph.It's my understanding that this is only works under 40 miles an hour is that true because I have yet to get mine to work seeing these threads above
Do you:Picked up my IX last week , tried push half way and all the way. The auto lane change Won’t work … Any other suggestions? Many thanks
