Does anyone have a Level II 50 AMP home charging devise? I believe the as-is BMW branded charger supports up to 40 AMP yet the M60 can support up to 48 AMPs.
I only know of the Chargepoint Home Flex that can do 50, but it needs to be hardwired in to your circuit for that instead of plugged into an outlet. ChargePoint Home Flex | ChargePoint Otherwise, lower amps are only available if plugged in.Does anyone have a Level II 50 AMP home charging devise? I believe the as-is BMW branded charger supports up to 40 AMP yet the M60 can support up to 48 AMPs.
Question about ChargePoint Home Flex.I only know of the Chargepoint Home Flex that can do 50, but it needs to be hardwired in to your circuit for that instead of plugged into an outlet. ChargePoint Home Flex | ChargePoint Otherwise, lower amps are only available if plugged in.
We originally were going to do the hardwired option, but because of it being too much trouble (and much harder to just take with us should we move), we just had the electrician install a NEMA 14-50 outlet and live with the 40 amp (which is plenty for an overnight charge).
Very useful thread. Thank youThis may help.
Juice box pro does 50 (the new unit does 48)I only know of the Chargepoint Home Flex that can do 50, but it needs to be hardwired in to your circuit for that instead of plugged into an outlet. ChargePoint Home Flex | ChargePoint Otherwise, lower amps are only available if plugged in.
