1 - 10 of 10 Posts
BMW iX xDrive40
Today I got an alert in the BMW app about a planned SW upgrade related to the airbag warning light fault.
The OTA (RSU) will be implemented no later then 2022-06-10.
I'm really happy about this since I had a workshop visit planned for SW upgrade due to different SW bugs that I now can cancel.
This is the first RSU that I ever done, so its going to be interesting to learn how its done.
I'm in Sweden, driving an Ix40 on SW 11/2021.26
Hi, my update was done today as I had the attached fault keep coming up so booked the car in for that and they advised there was a recall re the airbag fault. Apparently the drive assistance fault I was getting was already part of the update for the airbag recall fault.
Although I could override the drive assistance fault I didn't have blind spot or collision assistance active so I would switch of the ignition, open the door and restart the car and most times the fault didn't occur until I started the car again but not every time.
Hope this helps if you experience the drive assistance fault.
BMW iX xDrive40
Discussion Starter · #4 ·
Yes, the airbag "fix" will update all modules to the latest SW stand so I also expect other glitches from my early SW to be corrected.
Do I understand you right, you went to a workshop to get the SW update? Or did you get the OTA update?
Addressed before, but no. Nor have I heard of anyone else getting an update OTA - iD8 has been out almost 2 years, and by this time I had at least 4 updates in my X5 with iD7. Current version is reportedly 11/2022.25 - either an overabundance of caution, or of ineptness....
Apparently to go from 03/2022 to 07/2022, it has to be performed by the dealer due to the recalls.
BMW typically does OTA one release behind, so 11/2022 will be made available as an OTA sometime in early 2023.
Could be, although I went from 07/2022.33 (installed at the VPC) to 07/2022.45 with a dealer visit at my own request. Owners have reportedly had 11/2022.25 installed by their dealers, so 07/2022.45 should be available OTA right now, which it is not, or at least I haven't heard of it. It may well show up in 2023, or the latest version of 11/2022, but based on history I'm not holding my breath - if the logic was that they wouldn't release later versions of 07/2022 or 11/2022 because some cars still have 03/2022 on board, that won't change in 2023. I've seen BMW stall OTA releases before, mainly because they couldn't get their act together with reliable updates OTA, and I don't really expect that to change with the new iD8.
1 - 10 of 10 Posts
