1 - 2 of 2 Posts
What’s the quickest way to start preconditioning without pre-setting the departure time? And how long does it take to warm the battery in order to get best mileage?
Not sure if you are asking about car's climate temperature settings or battery pre-warming to prepare for charging?
For car's climate if I have not set up the departure time, just go to car 5 minutes before departure and turn on climate while car is connected to charging cable. Within minutes it cools down the car then you can unplug the charger.
I noticed warming battery would be needed to colder places. So far in California hot sunny weather, I didn't need to prepare much. Just plugged to DC charger and it started charging with high speed. It will be different story as weather starts to cool down. I assume as when you decide to go to charger or 5 minutes before you arrive to charger, just select the charging location on navigation. It should start preparing the battery for charging.
1 - 2 of 2 Posts
