Thanks.
J jeffgtx · Registered Joined 8 mo ago · 76 Posts Discussion Starter · #1 · 7 mo ago Only show this user Thanks.
J jeffgtx · Registered Joined 8 mo ago · 76 Posts Discussion Starter · #2 · 7 mo ago Only show this user Anyone? Alternately if you know the part number for the floating center caps, that’s fine too.
carchase54 · Registered Joined 10 mo ago · 151 Posts #3 · 7 mo ago Only show this user Probably someone from the dealer's technical team would be able to help. Did you try talking to them?
J jeffgtx · Registered Joined 8 mo ago · 76 Posts Discussion Starter · #4 · 7 mo ago Only show this user Yup. They threw up their hands. I’m sure the ix is a bit too new and the documentation is trailing the shipments.
R Rickardg · Registered BMW iX xDrive40 Joined Jan 21, 2022 · 95 Posts #5 · 7 mo ago Only show this user Pattern: 5 x 112 mm Centre bore: 66,56 mm Bolt: M14 x 1,25
J jeffgtx · Registered Joined 8 mo ago · 76 Posts Discussion Starter · #6 · 7 mo ago Only show this user Thank you
J jeffgtx · Registered Joined 8 mo ago · 76 Posts Discussion Starter · #7 · 7 mo ago Only show this user Can confirm the floating center caps for the 5x112 bolt pattern fit the 20” wheels.
