I was triggered by a post of brownbottle to do some research on DC charging stations. And I found some information, dealers will not tell you but it is worth to know.
A 150kW/175kW DC charger is designed to provide a maximum power output of 150kW/175kW, but this does not mean that you will always receive 150kW of power when you use it to charge your BMW iX. There are several reasons why you may not get the full 150kW output:
Remark: All 300/350kW chargers I know are equipped with water cooled cables.
- EV battery state of charge: The state of charge (SOC) of your EV battery will affect the charging speed. If your battery is low on charge, it will accept a higher charging rate, which means you may receive close to the maximum power output from the charger. However, if your battery is already partially charged, the charging rate will slow down to avoid damaging the battery.
For iX following charging curves are available:
- Battery temperature: Charging a battery generates heat, and if the battery temperature is too high, the charging rate will be reduced to prevent overheating. Conversely, if the battery is too cold, the charging rate will be limited to avoid damage to the battery.
For iX: don’t forget to select the charging point as destiny of your navigation system. The temperature of the batteries will be preconditioned to let it possible to absorb the 150kW. - Charging cable and connector limitations: The charging cable and connector used to connect your EV to the charger also have a maximum power rating. If the cable or connector is not rated for 150kW, the charging rate will be limited to the maximum rating of the cable or connector.
For iX: exactly this is the weak point.
Normal charging cables are limited to 400A or less. (Voltage is normally no problem as they are almost all designed up to 1000V). Water cooled cables are limited to 500A.
Now the iX has a 94p2s (iX40) or 94p3s (iX50 and iX60) battery configuration. This results in a battery Voltage of 94 x 3.5V = 329V. When charging at 400A, it will result in an absorption of 329x400= 132kW. For a cable supporting 375A, this results in 123 kW. If the charger is equipped with a water cooled cable the same calculation will deliver 165 kW and the charging power will be limited by the car to 150 kW.
For the same reason, the iX50 charge in the beginning is limited to 329x500=165kW. When battery Voltage is increasing when the SOC is increasing, power will increase by 500A up to 4.14V per cell (just below the 4.20 limitation for NCM811 batteries). Switching to 400A by the car will reduce charging power to 156kW.
Remark: The BMW i4 will not have this problem, since his battery configuration Is a 108p3s which gives a battery voltage of 108x3.5=378V resulting in a power charge of 142kW for a 375A cable and a 151kW for a 400A cable. - Charger limitations: While a 150kW charger is designed to provide a maximum power output of 150kW, it may not always be able to do so. The actual power output may be limited by factors such as the quality of the electrical supply, the temperature of the charger, and the number of vehicles charging at the same time.
This is logical from the point of view of High voltage electronics.
